Sonar G, need shematic with wiring for DC power cord
Adamf
243
30
38
70
Hi all, I have a Sonar G CB and need the wiring for the DC power cord, a schematic would show it, any help out there? Thanks for any help. Adam
Image below should be clickable. It's a scan of the Sams page with the 120 VAC and 12 VDC plug wiring. Sams CB-6 if you want to pick up a copy of your own.
Hey, thank you SO much, that helps a lot. Funny it does not say for the !2VDC lines which is positive and which is negative? Anyway, thanks, Adam
I guess looking at the rest of the schematic and the power plug on the radio it does show pin 7 is ground so that means pin 7 will be positive...Thanks, Adam
Glad you figured that out. I just happened to run into a reference for the right Sams, and there it was. I've never seen one of these in the real world.
