Sonar Model G & Model H AC power cord
retired06
Apr 3, 2009
Does anyone know if the "factory" AC power cords for the Sonar Model H and the Sonar Model G are wired the same way? I need to know if I can use the power cord from my Model H on my Model G without changing anything inside the CB radio. Thanks
Should be able to. AC is non-polarized. Just as long as the physical fit is the same. That's why you so see older-fashioned and some newer home appliances with the same sized prongs...you can plug them in the wall either way.
