SOS Scout Hummmmmmmmm
357
Walkin' the dog From Chilliwack BC
I Support WorldwideDX.com!
Sep 12, 2009
1,530
916
123
53
Chilliwack, BC
www.youtube.com
Let me guess: new caps through-out.
I got a big hum and sounds like I got robot voice on my 99v enabled.
Problem #2.) 6ME6 tubes in final. Can this be right?
it also has 6jg6 drivers
Major big time hum on TX
EDIT:
I think I found the answer:
Q "I have heard that capacitors can go "bad", when and how can I tell if mine are "going" bad?"
A "Computer-Grade" electrolytic capacitors have an average service life of from 15-25 years dependent on the level of ambient heat they operate in. These caps fail in only two mode, "open" meaning loss of capacitance, or "short" meaning a dead short, usually resulting in an explosive destruction of the cap. A shorted cap would be pretty obvious, but if your caps are "open" how can you tell this? If the caps are open, there will be a marked drop in the plate voltage under a "no-load" condition. Also, when under load, the plate voltage will drop severely, and it is possible that an AC hum or severe distortion can be heard on the transmitted signal from this unit. If your amp is over 20 years old, it might be a good idea to buy a replacement set of capacitors for your amp. Always replace the full set of caps.
Here are some pics.
Could i please get some feedback on the coil taps?
Can I shorten the coils for more efficiency?
Are they tapped correctly?
Also the "twin peaks" on tune/load.
What am I looking for and how do I get that sorted out?
Thank you!
Click on images for larger view
It sounds like you have a tube with a grid short. That will produce what you describe. Check the tubes to make sure they don't have leakage.
Maybe a cap in the HV supply? Does it do this in low and high power? I have had tubes cause this problem many times before.
It does it on low and hi.
only getting 150w carrier with backwards swing.
I will have to hunt down a tube tester.
I think new caps won't hurt either.
:bdh:
