Spt500 radial insulator
Van Lifeson
Aug 11, 2018
231
270
F7E072E1-9858-4A87-9FA2-5F67F03121FF.jpeg 2ED7F0FC-3E65-4C44-A6C6-7D5BD343D535.jpeg Can someone tell me if this black insulator for the radial plate is installed correctly or backwards? It looks like in the manual that the longer part should be facing the top of the antenna. Thanks.
That’s what I thought but I found lots of pics online of new and original penetrators with the short side up
View attachment 35437 View attachment 35436 Can someone tell me if this black insulator for the radial plate is installed correctly or backwards? It looks like in the manual that the longer part should be facing the top of the antenna. Thanks.
To me, you have it correct. Notice the larger flange is below support bracket. Alot of drawings are not to scale.
Reactions: r carl
