STRICTLY MY OPINION. ARE YOU LOOKING FOR A VINTAGE#WEEP TUBE AMP
Sonar
Apr 8, 2016
1,502
1,025
173
I'm in the process of refurbishing the 6 CB radio craze amplifies I already own. I've never owned a Golden falcon but I have done some research in the past as I was interested in a much smaller one at the time and wanted to know a little more about this amplifier and it's builder. Even though I'm working on getting all my sweep tube amps back to 100% or better operating condition I still have that little man inside my head telling me not to let this one go. So I got my eye on it although I probably won't bid on it. But depending on how high the bid is with about a minute left on the auction. I just thought I would share this as I know from reading Post written by people who are interested in purchasing a CB craze sweep tube amplifier There's plenty of information on each and every one of the golden falcons made. As far as CB radio amplifiers go it's definitely one of the better brands. So. If you are interested and looking for something you should look at this one as it is a very special amplifier. Like I mentioned above as far as CB radio amplifiers go and this brand is especially when compared to most of the other amplifiers. If you are not a tire kicker and or dreamer and are truly looking don't let this one slip through your fingers without at least doing some online research (I don't know the amps eBay seller. I'm sharing because there might someone looking for an amp that isn't familiar with the history or build quality of this particular brand.) If the bidding doesn't get out of control as I mentioned above I just might scoop it up myself. I Always wanted one and depending on the price within the last minute or so I just might pull the trigger. I'll hate myself for the next day but once it get's to My QTH all will be right with the world. if I didn't own as many amps as I do and wasn't in the process of refurbishing them all I'd have no problem making sure that this amp would make it to my front door as I would absolutely be sure I'd be the new owner. Just thought I'd pass on the info for those of you in the market for a base station sweep tube amplifier. They don't get much better then thees. 73 PS. I'm having an issue sharing the eBay add. If you're interested just go to eBay and look up Golden falcon 2000 amplifier. It's the only Golden falcon currently available and should bring you right to that item. Either way good luck. 73
https://www.ebay.com/itm/Golden-Fal...528843?hash=item41fe7dc24b:g:4S4AAOSwP2BcqBCi
Hey Sonar,
good to see you around.
Let me know if you need parts for your project, i probably have some of the old junk you will need.
Reactions: Sonar
Hey Sonar,
Thanks LC. I'm certainly taking my time this goround. I never thought the knowledge I gained throughout these almost 4 years as a wwdx member. As far as parts go I think I've got all that covered.
But one never knows until one runs into a problem. A problem that only particular parts can repair. As of now everything's going smoothly. I'm taking my time. I think that's the biggest lesson I've learned from everyone of you guys. Take your time! No need to rush. Rushing can only lead to problems from the get-go. And that's exactly what happened to me. I won't let it happen again. No matter how much time it takes to get this station in 100% dropper working order. Time is not a factor. And I won't allow time to get in the way of a properly working station and a very poorly operating one.
Slow and low let yourself go slow and low that is the tempo.
Thanks for adding the link. Much appreciated. 73
Global shipping program: at your door in perfect condition or your money back and get to keep the item.
Got my Acom 1000 free
Score!! I'm ass8assuit it was repaiablreand ]⁴
Free amplifiers! Exccelent!! Free anything is good. Especially an Acon. Big bucks for the ones iveI seen.
