Stryker SR-497HPC what a mess!
Sounds right, C212 is listed as M104 on the schematic, and I remember those green 104's being on the larger side.
Guessing here. I wonder if they added that cap to extend the higher range of frequencies that can pass around the regulator. If I assume an inch of trace and cap lead between the cap and transistor (about 20nH), the self-resonant frequency would be in the 3.5MHz area and going inductive above that. A ceramic chip of lower value might help keep RF off the regulator, if any were to leak back past the final chokes.
Reactions: Cable Guy
Given the additional shielding and intentional stage gain reduction, I would agree with you. Seems they put it all together and realized they had a problem. What value would you guess?
I doubt it would oscillate, but it might affect the modulation waveform a little. It might not even be necessary, and I could be wrong about the purpose.
I guess I would scope the regulator with a clean tone going in before doing anything else since it seems to be working.
    boog351 has left the room.
