Ok one says yes it will and the rest says no. So what now
that's not even the best part of the replies....the alleged output disagreements we see is just as interesting. output wattage is totally irrelevant. the most important factors are:
what transistors does the amp use
what transistors does anything before it use
what is the real world efficiency of the antenna/antenna system
and most of all-what wattmeter????
ameritron was pretty close in one of their ads....'xxx amp is only 1 S-unit below the legal limit'. THAT is what you should be concerning yourself with.
concerning yourself with a number may drive you nuts. for kicks, say you're replacing a dx500-as long as your dx1600 shows even a SLIGHT increase in signal strength over the 500...that's what you want. in theory, that's all you should get. 1600 watts vs 800 or 500 or s3 signal vs s9....all irrelevant.
for a better explanation, read my posts
http://www.worldwidedx.com/meters-m...60-dosy-watts-vs-bird-watts-5.html#post348577
my ic706mk2g generally runs 'barefoot', with the power setting on 'H', whatever the hell that may be. if that ain't enough, i back it down, to 2 or 3, sometimes 4, then click the dx1600 on. whats my output? beats the sh*t outta me. i can usually get out though...on 27.025. on 28.450, it's almost TOO easy, so i guess the wattage is....ENUFFTAGETOUT.
in case anybody asks why i would back the 706 down....i only have #6 wire in the xj
so you need to concern yourself with lotsa other things, not how many watts. with the end result being....am i running what i need to run to do what i gotta do. by the way, my 706 dialed down to '3', shows anywhere from 225 watts to almost 600, depending on which of 3 wattmeters may be in the jeep. all i know is, i can sometimes talk on the bowl & ALWAYS talk on 10m.
oh yea, as for not driving it to the max....my dx1600 was purchased around 1985, maybe earlier. i have driven it with everything from a stock grant xl to a 2x2879, with quite a bit of time being driven by a dual final export, and it runs just fine after over 27 years of abuse.
