SWR in Rain?
G
GONO2
Guest
Will SWR readings on a moblie go up, down, or be unchanged in the rain?
Thanks, Tim
Go Rusty!</p>
Mine do, on the base. I dont know much about it, but my Imax has gone from flat 1/1 to 1/ 3 over the past few days. It has been raining here for a week! Still not bad, but it has changed.
</p>
Mine in the truck with a Wilson 1000 don't change at all in the rain. My base used to when I had the CLRII up, but not with the I10k.
Base:
President Lincoln, AR-3500 (100 watt), KLV 550, Interceptor 10K
Mobile:
Magnum 357, Wilson 1000</p>
I'm told by guys who set SWR's, that they won't do it if the humidity is real high or it has been raining because it gives a false reading. Supposedly the rain will increase the amount of actual grounding that the antenna sees. Atleast that is what I have been told. 73's
Hoosier Camel Jockey
PE777 mobile 27.475lsb
10-10 on the side listening in</p>
If you get water in your coax because of rain, SWRs will definately go up. To prevent this, use Coax Seal or RTV Silicone around the PL-259 connector at the antenna. It probably should be resealed every year, right before the rainy season, as well.
</p>
