So...I left the window open in my truck and the 2800 got rained on. Then the LCD display was missing some segments of the numbers. I replaced the LCD thinking that was the problem. But it did not fix it. There was some corrosion on the circiut board. I cleaned that off. It did not seem real bad. Anyway my question is what do you think would be the most likely cause of my problem. I'm sorry if this is not much info, but it's all I have. Just looking for ideas, and suggestions. The radio works fine except for the display problem.
Thanks
Thanks
