A Winner has been selected for the 2025 Radioddity Cyber Monday giveaway! Click Here to see who won!
Seldom does the final AND driver fail. It is probably the final transistor.
Beware of phony final transistors. They are everywhere on eBay, and I would only trust the Eleflow brand. I have bought the cheap 'n phony 2sc1969 transistors from sources NOT on eBay too. Believe me; they are ALL phony.
Only one guy sells the REAL McCoy any more, and that is 'Eleflow'.
You can use either a 2sc1969 or a 2sc2312 transistor; they are interchangeable. The 2312 is even a little better than the original 1969 - BTW. You will also have to set the bias current ('mA') of the final. It wouldn't hurt to do the drive bias adjustment before the final bias either.
BIAS Current adjustments:
Set radio to CH 19 USB TX mode/Modulation Off.
Driver Bias: Connect current meter to TP7 (+) and TP8 (-) - adjust VR10 for @50 mA.
Final Bias: Connect current meter to TP7(+) and TP9 (-) - adjust VR12 for @100 mA .
