C45-91pFI was running amp on sideband and first key it smoked. Turned off and unfortunately no repair techs anywhere near me. Only thing I can make out on cap is 100v. This is right at the input coil. What do I need to check other than this and probability of bad transistors from fireworks?
Common failure cap. Needs to be replaced with a metal clad mica 91pf. A 100pf metal clad works too and easier to find. Better pic of the whole amp would help to diagnose the rest.C45-91pF
Absolutely update!Thank you. Have one coming. Would you mind if I keep y’all updated?
