you need a external power meter to put between the amp and antenna , find out what your radio will make the amp modulate (probally 500-600 watts) and adjust the radio to make the amp dead key %25 of what that ammount is.....about 125-150 watts .
the 667 is a awsome amp.but being a 1x4 amp its often overlooked cause most
if not all exports will overdrive it.i known people that had this amp
they loved it.but with the export type radios the 500 is a better match
been told a time or two that the TS 500 can and will out do a 667 if done right. Those TS 500s are a damned good boxes ! Freak'in bullet proof ! but most TS's are , they may crumble from the heat , the switches burn out , the meters take a shit and the face plates fall off , and totally look like they have been hit with a hammer a few times , but by golley , those freak'in TS's can take a licking and keep on ticking
If you want to use it with the Galaxy have a good tech disable the driver or have it were you can use the driver or not with a switch. Then it will work with both radios.
Straight from the texas star site and I'm sure 5 watts (RMS) would equate to 15-20 watts pep.
I used to run a dx500v with 7 watts carrier input and 45 watts pep with no fan and it stood the test of mack, I mean time. CW Transmitters(Models DX 400, DX 400V, DX 500, DX 500V, DX 667 and DX 667V)
These transmitters are designed for mobile or base CW operation. Powered by the 12 volt vehicle battery or 12 volt regulated power supply, the maximum power output is less than 5 watts RMS. Frequency of operation is within the 10 meter band, determined by installation of a crystal into the oscillator board. The transmitters contain a transmit/receive relay and an output connector for the receiver to share the antenna and permit break-in operation.
