Texas Star Dx400
kerryebro
Aug 3, 2010
57
Hi Forum I live in Arlington,Tx im looking for a amp repairman, more precisely some one who can really straighten out my mobile for base ssb work.
8176379066
The Texas Star 400 is SSB ready so all you need is at least a good 52 amp power supply. A 70 amp would probably be better. As far as input drive on SSB something like 8-14 watts would be plenty. You didn't mention anything about problems with your amp in your post. Is it working or is something acting up?
kerryebro:
"It works great about 600 watts pep. I'm starting to see high SWR on pass-thru and looking for a better tune on the lower freq."
He posted the above on CHAT Page earlier.
So not sure of the issue.
All the Best
Gary
LOL yea that's a problem right there a TS400 can't do 600 watts. Sounds like he needs a new watt meter and to stop overdriving the piss out of that thing.
It can make a meter say its putting out 600 watts but...
If you need to see 600 watts you need a bigger amp. The 400 sounds tired.
But,but,but,but
The spec sheet says.........
Quote
Don't think a data sheet, especially one lacking so much data as the one linked and only listing SSB linear tests, is an absolute limit for all modes.
End quote.
Ya.
Problem here is the rest of a DX 400 will not take the abuse the Toshiba transistors will.
But,but,but,but
Quote
End quote.
Ya.
Tell the datasheet guys that a 2879 amp can't produce harmonics. The datasheet says 2-30 mhz.
I'm all fairness to the OP it depends on how he is measuring output power.
We all know that you can set half a dozen, run of the mill watt meters behind a pa and see different readings, and depending if was running into a dummy load, antenna, what swr, so we might be assuming.
The 2879 was 1 hell of a robust transistor by the time the end came around, they had it together.
It would continue to work well above the 12.8 vdc that was used in the data sheet test jig.
The problem is that the Toshiba's will far exceed what the rest of the ts amp will.
  • @ heartbreaker3473:
  • @ AudioShockwav:
