Texas Star Modulator -no transmit
Unit 75
"TRAINMAN"
Jul 29, 2014
537
1,035
153
Central Alabama
Picked up one of these modulators. The relay works when I key the radio into it but I get absolutely no power output. I have tried 2 to 4 watts input drive to the amp The receive pre-amp button works and amplifies the receive, so the transistor is ok. ..just no power out. The variable pot on the front checks out ok. Is this a common problem with this model? Bad cap or something?
Not sure what model you have, I have a few dif ones. I do know most are input voltage critical. Just a bit low and it wont launch the finals. More info would be helpful. On another note I heard you blasting to the east coast yesterday :) One last thing, if unit is off does signal pass through it? 73's
Ocean One Cape Hatteras
Reactions: 2NC995
I have the one using the 2sc2290. The signal passes thru the amp when it is off and the signal does not pass thru when the amp power is on.
You were sounding awesome coming into my receive the other day. You were walking the locals here...lol
Reactions: ENC Pirate
OK, the receive amp is separate from the output transistor. No output usually is a bad transistor.
Reactions: Unit 75
