TH-D72
s55db
Oct 20, 2010
20
Hi,
how can I choose which fixed position will the radio use? I have stored 3 or 4 positions but don't know how to choose...
Thanks
73 de S55DB
I'm not sure I understand what you're trying to accomplish? Are you trying use a stored waypoint as your beacon info? Or are you trying to do something different than that?
I solved the problem...
I wanted to use stored fixed position from MyPostition menu 360, but didn't know how to select one.
You just have to press * on the keypad when memory slot number is blinking, the same as with User Phrases or StatusText, in the manual it is mentioned at that part, :)
  • @ heartbreaker3473:
