TH-D72A GPS Question
wa2chj
Feb 28, 2011
3
Has anyone else noticed that, when the GPS is running and has a postion fix, if you transmit on any frequency you get the iIzZ display during transmit like the GPS is in power save mode? Then when you stop transmitting, the GPS goes back to the iGPS flashing display and you get the GPS position fix tones. That's kind of annoying. I know I could turn off the tones, but I don't want to lose the initial GPS aquisition tones.
I can't find any documentation of this behaviour anywhere in any of the three manuals. Just want to make sure there's nothing wrong with the way mine is functioning.
I have the TH-D72 but have no audible tones when GPS has a position fix.
Can you tell me where I can turn those tones on and I will give this a test also.
Cheers,
Gerard
VK2JNG
Go into setup, choose the AUDIO menu. Hit the right arrow button and then use the top dial to scroll through the menus until you get the KEY BEEP menu. Hit the right arrow button, then use the top dial to scroll through the options. Choose either "RADIO & GPS" option or "RADIO Only" and then hit Esc to back out of the menus. The radio will now have an audible tone when it gets a GPS lock.
To answer the OP's question: Yes, my radio exhibits the same behavior. I never had a reason to to turn on the GPS beep so I never noticed it before.
GPS Question
Thanks, Moleculo! This behaviour seems somewhat strange, but I guess it was designed that way. It must need to shut down the GPS receiver during transmit either for power management issues or to avoid some type of interference. Appreciate you checking it out for me.
WA2CHJ
    63Sprint has left the room.
