Think they are called "trim pots"...
hollywoood
Dec 4, 2011
11
can you buy them and where?... Need one for Magnum S380 believe it's a 120 for L5 adjustment,... top adjusting part would not turn ended up breaking... Thank you!!!
If the part is actually marked as "L5" on the circuit board, then it's not a 'trim pot,' it's a variable inductor. (L is the symbol for inductance.) 'Pot' is short for 'potentiometer' which implies a variable resistor (a particular kind of variable resistor, with 3 terminals). Not the same thing.
In any case, I would suggest DigiKey:
Electronic Components Distributor | DigiKey Corp. | US Home Page
Or Mouser electronics:
Mouser Electronics - Electronic Component Distributor
You need to figure out what the inductor value is (in microhenrys (uH)) to get a replacement.
The ferrite slugs in variable inductors are prone to cracking if you use a metal tool to turn them. That's why a plastic adjustment tool is recommended instead.
-Bill
You can get these coils directly from "The Radio Shop" in Ontario CA. They are an authorized warranty repair station for Magnum radios.
Did you use a metal screwdriver when the coil slug broke? Hope not. Not supposed to use any metal tools when adjusting these coils; only nylon tools are specified. Using metal tools to adjust these coils is the #1 cause of breaking these core slugs.
Better still; think you are better off to ship the radio to either Bob's CB Shop or The Radio Shop - whichever is closer to you. I think that Bob's CB is still an authorized Magnum repair station as well.
Just $.02 . . .
You can these coils directly from "The Radio Shop" in Ontario CA. They are an authorized warranty repair station for Magnum radios,
Better still; think you are better off to ship the radio off to either Bob's CB Shop or The Radio Shop - whichever is closer to you. I think that Bob's CB is still an authorized Magnum repair station as well.
Just $.02 . . .
You are not supposed to use a cordless screwdriver either.
"You are not supposed to use a cordless screwdriver either"::eek:
Thank you for all the info,... the ferrite slug would not turn for what ever reason, started with a nylon, broke it with the metal, took a apart variable inductor and replaced the ferrite slug and nylon threads seems to be good..
Again, thank you and Happy Holidays to all!!
