Titan roadpro part ???
Sonwatcher
3,402
26
48
Colorado
The little center button you push to change freq came loose. Is there anyplace I can get this part ? It's the whole essembly of little buttons, their all in one unit.
Thanks,
Ron
</p>
Hello Ron,
I would try contacting RF Limited and see if they have parts available, since the Titan Road Pro is the same as the Magnum series of radios (with only one final).
www.rflimited.com/Contact...actrfl.HTM
Also, you might try Bob @
www.bobscb.com/bobs_cb.htm
and see if he could help out.
Happy Thanksgiving and good luck.
Paul
<span style="color:maroon;">CDX 8412</span>
<span style="color:maroon;">2 International Radio 473</span>
</p>
Thanks Slim !
So far I've tried the contacts people gave me and no results yet.
Ron
CDX-897
God bless you all !</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=sonwatcher@worldwidecbradioclub>Sonwatcher</A> at: 12/1/02 8:49:04 pm
Will do Slim.
Thanks ! <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
CDX-897
Try this;
RF Limited/ Magnum International
17725 NE 65th st.
Redmond, Washington 98052
I don,t have a phone #
OR;
keithele@csrlink.net
this is where I bought mine.
I hope this helps.
Jim <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/pimp.gif ALT=":hat">
The Peddler............
</p>
Well Slim it was a galant try ! But my buttons are totally in different places for some reason. Must be newer version. Thanks a lot for your help !!!
Ron
CDX-897
Well we tried ! <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Thanks !
CDX-897
Ozark,
They're just held together with thin plastic strips about 1/4 " or so long. That's what happened to mine,the cold. Rf-Limited has them( they're all part of one unit } for around $10 plus shipping. I haven't sent for mine yet as I have the button placed in it's hole with scotch tape over it <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/happy.gif ALT=":D"> . It's not hard to replace. Just remember that after you take the screws out you MUST unscrew the outer nut that holds the mic connector to the face of the radio. If you don't and pull on the face you could break it. Then there are a couple of pull tabs you have to bend back after the face plate is removed. Then I think only 4 screws hold a guard over the button assembly. That's it ! Hope this helps <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Ron
CDX-897
The button assembly is $10.00 + shipping. If you would like to order please call 1-877-624-6869
I asked for the button assembly for a Magnum 257 as it is the same.<img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Sonwatcher
CDX-897
