Tram D 80 clarifier mod
It uses the 511 chassis.
Never did one; but guessing it would be the same clarifier mod as a Uniden/Pres Grant, Washington, or 142GTL.
Perhaps someone else can say for sure.
I found this on the net hope it helps
Tram D80
I think its the same board as the d300 base
Tweaks and Peaks
Modulation: Cut R104
AM Power: Adjust VR6
ALC: Adjust VR7
Yep, same as a Uniden Washington. I had sent you the wrong info, Sorry about that! :oops:
Remove D36, and R187. Remove red wire from PCB and move it to pin 3 of the MB3756 voltage regulator. I actually put it on (+) side of C66. Remove Brown wire from the PCB and connect to PCB ground. That should get you unlocked.
~Cheers~
