Got tired of working on this thing, so I thought I would write about it instead.
On the bench is a Realistic TRC-448. It has problems. But I'm working my way through them, slowly.
First problem, power cord. Easy enough fix, just pull out the remains of the old one and put the new one in. Simple, right? Nope. Followed the "original" wiring as it was in the radio and the new one... trips the power supply overcurrent protection? Well, that's not a good thing. Start looking for shorts and not finding any. Happened to look in the right place and noticed the little line from the power cord hole to the circle with a "+" in it hidden under some components. Just so happens the black wire is in that hole, just like the old cord. Yep, I followed a bad example. It does explain why they cut the power cord next to the back of the chassis, though. Swapped the wires around and did a quick power test, lamps came on and the channel display showed me a number. Good enough for now.
Next up, volume control shaft bent. This actually was an easy fix, since I had a parts donor chassis that I had previously stolen the Plessy chip out of to work on a Console V. Stole the volume/rfgain/on-off control and swapped them out. Works like a charm.
Next up, Q218 was blown apart. Probably not going to work very well in that condition. Stole one from the parts chassis.
Meter appeared to be stuck. Yep, parts chassis again.
Found the nylon screws broken on Q2, Q229, Q235, and Q236. Raid my spare screws and nuts and add little plastic insulators for the tab so they don't short out. Now I need more spare screws and nuts.
Pulled some glue out that had been left when a previous owner recapped it.
Found that the two 1 uF electrolytics on the mode switch weren't put back on correctly during the recap. Fixed that.
Now I was finally ready to see if it did anything. Yeah, it does stuff, just not what it's supposed to.
Found that the LSB LED was constantly on. Another look at the mode switch showed two points wired together that really shouldn't be. Removed the solder and little chunk of wire between them, so that works as it should now.
Found that I could kind of receive something, but only when flexing the PLL board. Which isn't really ideal. Tried looking for any obvious broken joints, none to be found. Start working my way through the board, reflowing a little at a time and rechecking. Managed to find a disconnected component lead buried under the bodge resistor on the back of the board, but that wasn't it. Finally tracked it down to one of the channel selector connections. I'm guessing the one that kicks in an "out of lock" signal when you're between channels. Now receives without flexing the board.
Which brings us up to current. Radio is receiving a signal as indicated by the meter, but there's no AM RX audio. There is RX audio in sideband. More concerning is that in all modes there's an audio frequency oscillation that kicks in when the volume gets above a certain point. In sideband it mixes with the incoming 1K tone on the AM signal I'm injecting and it sounds kind of nasty. Not that it sounds good in AM.
I haven't even tried to transmit yet. I'm sure that will be an adventure as well.
Anyways, feel free to ignore this thread. Or mock my meager skills. Whatever.
