TRC449 LC audio filter
brandon7861
Loose Wire
I Support WorldwideDX.com!
Nov 28, 2018
2,638
2,937
293
I got distracted while looking at the vintage realistic thread. I saw an audio LC filter. Most often I see RC filters for audio, so I thought it would be fun to try putting that into circuitlab. I combined the model with the service manual image of filter response. Thats all, just thought it might interest someone. Sweep is from 100Hz to 10kHz
hey Brandon,
first, very cool!
i need to get circuit lab!
can you try using a 400Hz tone instead of a 1K tone and show those results?
the reason i ask is because of something i've always noticed about this chassis when doing the alignment.
the PEP output of the radio seems quite a bit higher when saying "ahhh" into the mic as opposed to using a 1K tone, and i always attributed this to that circuit.
many people might not notice this because so many of these radios had that section bypassed. it was a VERY popular mod back in the day.
but if you have one that is stock, i have found that using a lower tone frequency that resembles the male voice will provide a higher output.
anyone else notice this?
Where it says 1kHz, thats just there for an initial generator value. When I did the frequency sweep, it ignores what that generator is set to and sweeps the selected range. That chart sweeps 100Hz to 10kHz, so it includes a datapoint at 400Hz.
I made a minor change and re-ran the circuit, I added the proper part labels and added C60 and R100 to better match the low end response and a load of 10k to represent the input at TR16. Not much changed besides the low frequencies dropping off a little faster.
I can understand aahhhhh showing more power since it is harmonic rich, but I cannot explain a 400Hz sine wave producing more power than a 1kHz sine wave. It would be fun to run a sweeping tone into the radio and follow it to see where 1kHz drops below 400Hz. Could the mic response be to blame?
Reactions: Cable Guy
@loosecannon As for getting circuit lab, its just a website. There is nothing to download, you just go to circuitlab.com and make an account. It will let you play around with it for free, save a couple circuits, and run a limited number of sims.
I think I paid 70 something for a year subscription. It comes in handy when you have a kirchhoff-type situation with diode junctions and you are not feeling mathematical.
thanks Brandon,
not sure how i misunderstood that you swept the freq range LOL!
its my friday and its been a hell of a week, yeah lets go with that.
i'll be sure to check out their site. thank you.
Reactions: brandon7861
