Tuning imax 2000
Splash1
308
5
ordered new coax for the imax2000.in order to save time ,anyone remember how the tuning rings work ? does turning the rings up lengthen or shorten the antenna ?
they are usually pre-tuned .take it out the box put it together and put it up .if you do need to move the rings make sure the rings stay together .dont spread them apart.
Medina,,no,its not a new imax,its a new coax,..i just forget how the rings worked,its been so long since i tuned it i figered if i asked here i might save myself a few trips up and down the ladder adjusting the swr..
lower the rings to make the imax longer,raise the rings for shorter. if your swr is worse on your lower freqs., lower the rings to make antenna longer. worse on upper channels,raise the rings.
