uniden 68/78 with weatherband
hotrod
Feb 16, 2007
2,534
408
93
n.w pennsylvania
can these be modifiyied with the rx75 on the back?
i travel on weekends alot and would be nice to have the weather bands
to keep a watchout on wether in different areas in go into.
i havent heard of anyone putting the rx75 on these so was curious
Those are basically the same radios under the hood as a Cobra 25/29. Some people like the results, some don't.
Install information can be found for the Uniden 68 and the Uniden 78 very easily.
Here is the RFX-75 info page on CBTricks.com. You can compare the installs for the Unidens to the Cobras for yourself.
Ted
If you're looking for opinions, skip the RFX-75 and get a cheap 2-pill amp instead. It will out-perform the RFX-75 setup and will allow the amp to do the work and not the radio.
I have a Uniden PC68-Elite that I've run behind a TNT-350HD, Midnight Special 500 and RM Italy 300P, all at different time and it's worked well.
I called Doug at custom cb radios to ask if this mod could be done on a Cobra 25 LTD WX, the brother to the Uniden PC68LTW. One of his workers said it can be done, but they're all out of RFX75's right now. I guess they must be a popular hit with truck drivers who can't run linears.
well i travel on weekends with daughters softball team. and need something
i can take in/out quickly.not a permate install
