O
oldslowchevy
Guest
hi everyone. i am not new to cb's at all though i am new to working on them.
i did do a swing mod that works really good but it was sujested to install a 2sc1969 final in it. though i am haveing a very hard time finding a "real" 1969 final,....soooooo i just left the stock final in the radio.
so looking around i found 1 final a tip120 specs are:
power dissipataion 65watts
collector emitter votage 60 volt
collector base voltage 60 volt
emitter base voltage 5 volt
collector current (continuous) 5 amp (peak) 8 amp
base current 120 ma
the other that i have is a mofset a irf510 it's spec are as follows:
Vdss =100 volt
vgs +- 20 volt
Ip = 4 amp
dm = 16 amp
Igm =1.5 amp
Pd = 20 watt
both of these were bought at radio shack and item numbers are 276-2068 for the tip120 and 276-2072 for the mosfet.
which of these are worth it or are they? if the mosfet is... is it a plug and play or is there more work to be done?
i do not know what the stock final is in the radio and to be honest i am to lazy to take the radio back apart to look to look...... sorry.
i have seen nothing on the net about convertto the mosfets that i could make heads or tails of......... i'm not that bright...... but i can lift heavy things.
base current 120 ma
Vdss =100 volt
vgs +- 20 volt
Ip = 4 amp
dm = 16 amp
Igm =1.5 amp
Pd = 20 watt
