Uniden PC76XL
look to see if D-11 is in the good , both bottom and upper side , clip on top and might have a jumper on the bottom, the limiter really doesn't need to be clipped in that radio .VR-4 will give you all the audio needed. If D-11 is disabled ? VR-4 won't work. Even still ,the radio does have a mic gain. 8)
d-11 is marked on the board . Maybe you can understand the other guy better then I. Good luck to you.
you can just solder it back together , theres no jumper because they clipped it instead , Now VR 4 will work (VR-4 is modulation) you can just turn that up all the way then back it off a quarter or so.
