Sounds like your all set. The normal order I suggest is first have a proper tune done, then look at a nice small amplifier in the 150-250 watt range. That will give you the most bang for the buck. If your a big talker and want to sink just alittle more into the amplifier then look at a 2 pill with 2879 finals from X-Force, Davemade, AM Power, Fatboy. They are all fan cooled and would get you into the 350-380 watt range easy.
