unlocking clarifier on washington?
How about this ? ...........1)Cut d-52 and r-148.Find r-174 and solder a wire across the resistor.
2)Find the RED wire that comes off the clarifier control and cut it just before it connects to the PCB. Take that wire and solder it to GROUND on the PCB
3)Cut the orange wire just like the red wire but solder this wire to pin # 3 of IC-4 the MB3756 ic regulator. Should give you about 6 khz of slide
thanks jim, I will try that. not sure where IC-4 is but I will try it out, I will need to get me a schematic also for the pinout on the regulator so I get the right one. Does the pin just provide 8 volts?
