Up Down, button Mic Mod
Rogerbird1
Apr 24, 2002
525
133
53
Massachusetts
rogerbird.tripod.com
You will need 2 unused wires in the Mic Cord.
you can drill and add 2 Normally open pushbutton Switches
to the Mic. Connect one side of each switch to each other, and then to the the wire connected to Pin2 of the mic connector (Ground , Sheild or Common).
Connect the remaining connection of the 'UP' Switch to wire connected to pin 4 of the Mic connector.
Connect the remaining connection of the 'DOWN' Switch to wire connected to pin 5 of the Mic connector.
For more help see the Mic diagram at:
Accessory and MIC page
I hope this helps..
Roger
</p>
I hope this helps..
Roger
</p>
I was wondering, is it possible to mod my Astatic 575 with up/down buttons ? If so how can I do it
</p>
</p>
