Good Day Everyone,
So, I have now a Sinadder 3 that was calibrated in 2020. I have a few questions on aligning a receiver with it. I understand the fundamental operations of sending a 1KHz tone through the receiver and the notch filter is allowing that signal through "listening for" or measuring that tone. Sinad would be the comparison of the noise outside of the 1KHz tone and the tone itself. The lower the noise the quieter the receive. We make adjustments to the radio to maximize that reading/signal. While in the Sinad mode as you make those adjustments there is a scenario where you are lowering the noise and distortion but you are also taking the radio out of alignment therefore lowering the reading as well. How would you suggest or explain the logic of making the adjustment for the lowest sinad but maximizing the receive strength? The only factor that I can see with this device is the audio tone that you can hear. If the volume of the tone begins to decrease then the radio alignment is getting worse.
Any thoughts here?
Any thoughts here?
