My question is:
The 1st step:
Can I adjust the AM frequency by setting the radio to CH 1, AM, RX mode, clarifier control to center detent, and adjust L20 until I get 26.965 MHZ shown on radio's onboard freq. counter? I'll also compare these numbers to the other coaxial external frequency counter which will be in line??
The 2nd step:
I will set USB freq. by setting the radio to CH 1, USB mode, clarifier control to center detent. Whistle while transmitting on TX and adjust L21 until the frequency reads 26.965 MHZ.
The 3rd step:
Iwill set LSB freq. by setting the radio to CH 1, LSB mode, clarifier control to center detent. Whistle while transmitting on TX and adjust L22 until I get 26.965 MHZ...
Can anyone tell me if this idea will work or do I need to purchase another expensive freq. counter so I can use the numbers and test points that CB Tricks show to use?? Thanks for any help you can offer.... SD002
