Valve amp powering for mobile
  • Thread starter Thread starter subs757
  • Start date Start date
S
subs757
Guest
Not sure if anyone has done this. Is it possible to power a big valve amp from a big power converter, 12Vdc to 240 V ac ? Obviously for mobile Use. Battery bank an all if necessary.
Not sure if the quality/purity of the 240v sine is suitable or not ? I am giving due consideration to the mechanical shock mounting of the unit if this is possible.
All input appreciated as usual.
<img src=http://home.comcast.net/~shockwav/greatbrf.gif ALT=":*cacflg">
26 CDX 757, One of Our Subs - subs757
mobile with RCI2970 Astatic575 Sirio 7/8th @120w back at base Yaesu FT757GX Datong FL3 filter Astatic575 3ele Sirio yagi @130W
More than 2000 people are injured by teapots each year in the UK !</p>
Nope, you cannot run the whole amplifier off of a DC to AC power converter (typically called an "Inverter") because, the Inverter works at an audio frequency, the DC voltage has a "whine" associated with it
You can light the tubes and run auxilliary voltage supplies (bias and screen) but you cannot use it for high voltage.
To generate B+ (High voltage for plate supply) you should use a 3 phase transformer (13.6 volts in / 2000 volts out). Peter W. Dahl Co. in El Paso, Texas makes these transformers
CUTTING THRU THE BULL-SH*T
World-Wide in 'Da Buckeye
</p>
Thanks paws, i i wasnt sure on what ripple frequencies would be present to cause problems.
Cheers
