OK, I might as well use some more of you guy's knowledge. I have really gotten some great help here and it is much appreciated.
Lotta smart dudes in here.
I replaced all four pills in my little four pill, (with used pills, but they checked out great), but now the variable power only works when it is set on high, or wide open. This is on an Apache. If I turn the power counterclockwise or lower, it shuts down the output. It does have full output on the highest setting. I changed the potentiometer out, but still had the same problem. So I put the other one back in.
I replaced 4 bad pills with brand new ones on a Texas Star 500, and had the same problem.
What do you think?
What do you think?
