Vert or Horz??
K
KD5VHF
Guest
Most mobile and repeater antennas are verticle so you would want Verticle for this. Most SSB work is horizontal so you would want Horizontal for SSB.
73, Mike KD5VHF@hotmail.com</p>
I've got a 2m 12 element M2 yagi on the way. I can see horz for dx but how about for local repeaters as well, 30 miles away? Would it be better vert or horz?
Thanks,
Jerry
CDX-350
2AK3350
RL39</p>
I’m assuming you got the beam for SSB DX? Then leave it horizontal, even though the repeaters are vertical you will still be able to hit them cleanly. Though if you want to work FM simplex with mobiles, then you will need a vertical also.
Don’t know how much experience you have with beams, but that 12 element will have a narrower beam width then a 4 element. So an Omni antenna would compliment the station. I have a Diamond vertical for omni and the 20 element beam (10 horizontal & 10 vertical). If I only have a couple of S units on the vertical, it sometimes hard to find them on the beam, unless they give out a location.
</p>
Get a Quad. Feed it so you can do both. One of my locals does this and it is outstanding.
</p>
<blockquote>Quote:<hr>Get a Quad. Feed it so you can do both<hr></blockquote> Sounds neat.How ?
73, Mike KD5VHF@hotmail.com</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=kd5vhf>KD5VHF</A> at: 1/20/04 5:29 pm
I would think that thre's a way that hasn't been suggested yet. Try mounting the beam horizontally and hitting the repeaters. If that's possible, then there's not really a problem, is there?
PS - If I missed a post with this suggestion already in it, I have a good excuse. I just finished my taxes... I don't want to talk about it either!
</p>
Yeah, what Doc said...If they can hear you local mounted horizontal, who cares?
</p>
Thanks for the reply's.
That's what I was wondering, I should've worded my question more precise. I wasn't sure on FM if you would get that warbly sound when using horz locally like you do with ssb for local use when others are running vert.
I looked at the CP models, but wasn't sure how circular did for local. Since those were more for eme design. I really want to be able to get the longer repeaters as well, lets say up to the 200mile range. I had about decided to go ahead and mount in horz and if I get problem with the local repeaters and local simplex, I'll stick a smaller vert up there as well for shorter range. I was trying to get one that would let me get some good out of local and dx without running muliple coax lines for each. ( I know, don't laugh) <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/smile.gif ALT=":)">
Since the beam is so tight, I was seriously thinking of one of those M2 HO loops for listening. They're small, and I'm guessing I could mount this above the beam?
Thanks again.
Hey Doc, tax wise, I'll trade you. <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/roll.gif ALT=":rollin">
Jerry
CDX-350
2AK3350
RL39</p>Edited by: <A HREF=http://pub86.ezboard.com/bworldwidecbradioclub.showUserPublicProfile?gid=tumbleweed@worldwidecbradioclub>Tumbleweed</A> at: 1/21/04 6:34 am
<blockquote>Quote:<hr>I was trying to get one that would let me get some good out of local and dx without running muliple coax lines for each. ( I know, don't laugh)<hr></blockquote> Just use a external coax relay. I'm putting up a dual band vert above a UHF beam above a VHF beam with a single run of coax to the tower. They can be found cheap at swap meets or on E-Bay like this one... Transco <img src=http://www.ezboard.com/intl/aenglish/images/emoticons/wink.gif ALT=";)">
