hey 2mguy what larsen do you run and do you run 6m in the mobile.
C2 said:da pills be costing more too
dBd
dBm
dBc - relative to the carrier
dB - gain
an 18 dB gain amplifier will amplify the signal 64 times---that is 1W in means 64W out. 10W in means 640W out, assuming it is rated for that input level.
If it's rated 18 dBm input and 18 dB gain, then you would have 36 dBm output at that drive, which is just a hair under 4W output.
30 dBm = 1W and 40 dBm = 10W
