VHF/UHF & 800Mhz Duplexer
K1LA
Nov 13, 2011
19
2
13
Thanks in advance for any tips and advice!
I'm looking into the best/cheapest and most effective way to end up with a duplexer that would allow a 2M/440 antenna and a separate 800Mhz antenna to feed one transceiver.
In my area I do a ton of work on 2M/440 in the mobile but also love heading the local FD which is a 800MHz analog fm system. While the wideband 2m/440 antenna provides relatively O K reception on 800, I imagine adding a dedicated 800Mhz antenna would greatly improve this (and help overcome the icom 2820s slightly sloppy 800 sensitivity). Unfortunately I don't see any off the shelf duplexers for this solution.
Thanks again for any help
Evan
K1LA
Reactions: david1303
