Virage VX 68?
  • Thread starter Thread starter NorthStar34
  • Start date Start date
N
NorthStar34
Guest
VX-38 AND VX-68 MOD
1.. FIND J28. MOVE JUMPER PINS FROM 1-2 TO 2-3.
2.. FIND J4. UNPLUG AND PLUG INTO J2
3.. ON THE BAND SELECTOR, THERE IS A WHITE, RED, AND BLACK WIRE. REMOVE
THE WHITE WIRE THAT IS SOLDERED TO THE RED WIRE AND SOLDER THE WHITE AND
BLACK WIRES TOGETHER.
4.. THE HI/LOW TONE SWITCH NOW BECOMES THE HI/LOW BAND SWITCH.
</p>
I need to know how to fully convert this radio to 11 meters. I have moved the 3 pin wire plug to the right socket in the front of the radio & moved the jumper over as needed. There is something else that still needs to be done. Radio has no resistor on top of board to remove as you would a Ranger 6300 or 6900. There has to be a wire that has to be moved. I need to know asap. Please do not respond unless you know exactly what i'm talking about. Thanks
superduck<img src=http://users.joplin.com/dutch64804/posticon60.gif ALT=":60">
</p>
Thank you NorthStar34 post my Virage VX-68 now does 11 meter is their any other modification especially to the clarifier ? My peers says say I sound like crap when in ssb
Sincerely
Mixminister
Jamaica W.I
  • @ heartbreaker3473:
