VX-8R AA battery
KD8LWX
162
I have a AA battery pack. I don't like it because when I use it, I can only have 1W output.
Can I increase output by changing the type of batteries I am feeding the battery pack?
I was thinking something like Protected UltraFire 14500 AA sized 3.6V Li-Ion Rechargeable Battery 900 mAh CR14500 Lithium Ion
The other part of me is thinking that the VX-8R doesn't have a way of regulaing the 3.6V down to something more reasonable.
And I don't have my multi-meter here to measure the voltage coming out of the standard VX-8R battery.
The standard battery is 7.4 volts (says so in on the battery and in the manual). I actually see about 8.5 volts on a multimeter with a full charge.
The manual does say that at 4.5 volts (what the AA battery pack supplies) you only get 1 watt out. It also says that the battery pack is designed to only handle alkaline batteries. Regardless, I bet that you could use some higher voltage batteries. The ones you suggested will deliver too many volts, though. You'll want a battery combination that delivers around 7-8 volts total.
I am looking high and low for more powerful batteries. I have even considered only using 1 or 2 batteries with a dummy battery or 2.
I have a feeling this is a dead end project.
