W9WDX Homebrew D-Star repeater running new software
Ham Radio Nerd
Apr 14, 2002
9,200
1,686
283
This past weekend, I changed the software that I'm using for the W9WDX D-STAR repeater from WinDV (DV-Node) over to the G4KLX software. The two applications I'm using to run the repeater are called "IRCDDBGateway" and "GMSK Repeater"
I decided to change the software due to a problem I found where WinDV thought it was still connected to a reflector even when you told it to disconnect. The result was that it gave an error that local users were "doubling" with reflector users.
The G4KLX software is really slick. He updates the code every few weeks and it runs on both Windows and Linux. He also has an application that will let you work D-Star with just your computer (more on this later).
This stuff is really pretty easy to get going - anyone that wants to dabble in D-Star should really think about trying this out.
It's MUCH cleaner & quicker linking and unlinking now, but the really cool benefit is that I didn't have to wait for the repeater to drop to unlink. On the old software with a couple of long winded "OM's" yacking away, you could be 10-15 minutes trying to get the unlink command in between them.
