'K.M.D.',
The simplest way of thinking about propagation is to think about it as light reflecting from a dirty mirror. A 'dirty' mirror because some light is lost each time it's reflected, same with an RF signal. Some of those reflections will be off of the ground, some from the various layers of the ionosphere. Little bit lost each time it's reflected so at some point there isn't enough left to see/hear.
The ionosphere around the earth is composed of several layers, each reacts a bit different from the others. Deals with the gases that are present at that altitude. Each molecule of that 'air' gets charged and acts as a 'mirror' for electrical signals. Then there are those kind of layers that are composed of very little 'air' but lots of ions, charged parts of an atom, sort of, that get 'blown' off of their original 'molecule'. (That's sort of a long 'stretch', but as long as this is just for general information, it's close enough.)
Where does those thingies in the various layers of the ionosphere get their charge? Mainly from the sun. The light and other radiations from the sun tend to charge things when they 'strike' them. The sun also gives off free ions which are 'looking for a home', and some of them take up residence around the earth (and just where DID you think that song came from?).
The ionosphere changes shape and altitude depending on where above the earth that particular part happens to be. The difference is exactly like 'daylight and dark'. It sort of swells up in the lit regions, sort of shrinks in the dark regions (forget it, I ain't touching that one!). The largest rate of 'change' is on the horizon during sun rise and sun set. Because of that rate of change, propagation in those regions tends to be 'better' than before and after sun rise/set.
There you got it, the short version. No idea where to tell you to find the long version, but there's a bunch of places you should be able to find it. Good luck.
