Cheap N' Good would be Antron99. It's a heavy duty straight stick, easy to assemble and put up, super low wind resistance. There's a million of them in use. They're around $45. Can't go wrong.
All good suggestions. I suppose the cheapest would be making your own 1/2 wave dipole, or 1/4 wave ground plane.
But I had an A99 for years up at 50 feet with an RCI-2950, and worked the world with 25 watts. It seemed like about 1 out of every 3 guys I talked to were running more or less the same setup!
booty had it right w-5/8 is better than asstron 99 or the shitduster a clear winner.if your trying to save the 15 dollars you might as well make a 1/2 wave dipole and hang it vertical,i did and mine worked as good if not better than my asstron 99 with groundplanes.good luck.
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
