Which size Balun?
Peter Walker
Feb 23, 2011
119
60
What determines which Balun you need? I have seen 1:1, 4:1, and 12:1 Balun's mentioned in a number of articles. Is there advantage to one over the other? Is there a formula to figure it out? Could someone please help?
Very basically, you need to know the input impedance of the antenna. Divide that input impedance by the feed line impedance and you have the ratio for the balun required. Since antenna input impedances can be almost anything, the most common way of determining which 'size' balun to use is to select the closest one to the impedance ratio between antenna/feed line. If it's close it should make things usable. It'll probably never be exactly 'right'.
Huh? If you are using a typical T network tuner into balanced line the feedline impedance is not being matched. You are matching the antenna system inpedance. The actual feedline surge impedance only equals the antenna system impedance when the SWR is 1:1. Since most balanced wire fed dipoles are built to take advantage of low feedline loss at medium to high SWR levels, the feedline impedance will not be matched in almost all cases.
The original question was just about the balun and didn't mention a tuner at all. And of course the "tuner" doesn't do anything to the feedline impedance; all it does is provide an impedance very close to 50 +/-j0 for the transmitter. If the "tuner" is sitting in the shack next to the transmitter, everything downstream from the "tuner" remains just as it was before.
Since a BalUn transforms a BALanced system into an UNbalanced one (as in going from parallel feeders to coax), the BalUn's ratio needs to be carefully selected so as to provide the "tuner" with a ratio or span of ratios into which the "tuner" can work without difficulty.
The "tuner" doesn't do anything to the feedline impedance; all it does is provide an impedance very close to 50 +/-j0 for the transmitter. If the "tuner" is sitting in the shack next to the transmitter, everything downstream from the "tuner" remains just as it was before.
This is excellent review for those who might need it.
I don't see anything at all about balanced feed lines in the original post. Or about tuners for that matter. So, if a (balanced to unbalanced) 'balun' is required then I would assume that coax is the feed line being used. Wouldn't you??
Pretty safe to assume unbalanced on one end and balanced on the other.
Usually someone asking for optimum ratios has been cruising the WWW and seeing the QRM on the subject.
I can't make that assumption because of so many people believing that winding a few turns of coax close to the feedpoint constitutes a "balun", when all it is, is a choke for common-mode current. It's still coaxial cable, and therefore UNbalanced, at the end that connects to the antenna.
When one looks at a 1:1 balun like a black box and lists each and every thing it does, one can substitute a coaxial choke with the proper amount of turns for the frequency of operation into that black box and realize it is indeed a balun. If the coaxial cable continues for any length past the coil all bets are off.
Check out Walt Maxwell's description of his balun and how it was designed. Notice his is coax cable with ferrite beads. Still comes out coax.
Mods, nuke this if links aren't allowed.
The Labor Pains and Birth of the W2DU Ferrite-Bead Current Balun
