Regarding said antenna, I use this antenna exclusive and have had the very best of luck with it.
Some things just work
and this one works great and it is used by me this way.
I use it on the Even Harmonics Bands, 80 actually 75 meters after triming it some, and
40,20,10 meters...
I use a TS530s and No Tuner at all and output Is the same on 75 meters as well as 10 meters..
With a TS 50 and a AT 50 auto tuner, I work all even @ odd bands with no problem at all
and have full power out from both rigs.
From experience I will tell you some things that are a must do... Keep it in the Clear and that means at least 6ft. from tree limbs and do not run it over
Any buildings least of all any metal ones..
Follow directions to the tee and if you are going to run power then Up Grade the Balun..
There is a hot side or plus side if you will !! thats the long side and if and when pruning antenna DO NOT take off a even amont on both legs,
but instead take for Example 12 inches off long side then Only take 4 inches off short side.. or 1/3 of whatever..
I found the crimps will need to be replaced and not reused after triming as they just will not hold the wire afterwards.
Use coax seal on all exposed wire and on antenna feed at the balun.
If I were to do it again I would furnish my own coax and if, you are not going to use a center support then RG8x is the one to use as 213 will be to heavy.
I run a hundered feet of RG8x and found that a additionl 9ft was needed for the match ? also mine is at 35 ft on the ends with a 2 ft sag in the middle with no center support.
Also I am using the standard 1kw pep balun and not the high powered one, and if I was to buy today the high powered 2kw one is what I would get just for the Grins
If you talk to Buck and he gets testie with you Just Ask Him, what bit you in the Butt
and he will get right with you then !! sometimes Us old folks get up on wrong side of
the bed ! Its what happens when you stop getting any
hehe
Hope this is of some help and catch you on the bands..
Best Regards,
John- kd5wjy
