Workbench/frequency counter hookup
2FB327
270
55
38
Picked up a Tebna 72-4095 and why the book explains all the controls, I need some help.
1. What type of probe will I need or can make to pick up the signal?
2. It's has a channel A and channel B, is it possible to hook it in line with a scope?
I'm looking at doing bench repair, so is it possible to probe the radio and have the signal go from the probe thru the counter into the scope and then to the dummy load?
Thanx
Thanx
Not very practical. Connect them in parallel across the circuitry you're measuring. Be careful not to exceed max peak voltages, especially across the counter. 10:1 probes should be presumed to work until proven otherwise.
Thanks
Thanks you both for your quick response.
I'll keep the counter seperate, it's starting to make sense.
Still waiting on the scope to arrive.
Could you recomend a supplier for probes, connectors, cable, etc?
Once you've built an RF Sampler, you can run that to a 'T' connector. You can build one of those too. From the RF Sampler to the 'T' connector and from there to the scope and the other to the counter. OF course, this setup is used to sample radio OUTPUT; not sampling signals from inside the radio.
http://www.worldwidedx.com/home-brew/32110-rf-sampler.html
I use a probe and a freq counter to test the Reference Oscillator crystal ('RO'), where a signal can be monitored from one leg on the PLL chip. Just about every radio has an RO and they must be within freq tolerance, or you must replace it or adjust it. Many radios don't have an adjustment for this crystal; so you either replace it or add a compression capacitor to one leg of the crystal so it can be adjusted and pull it back into specs.
SO long as the probe you get is 10:1 attenuated and has a tunable cap in it (most of them do), it should work OK. If it has a swichable attenuation built in; so much the better but not necessary. Probably get one from eBay or several places on the internet. Not too expensive and should be about ~$25.
https://www.valuetronics.com/detail...gclid=COamsLGiuLkCFaU5QgodnXAASw#.UiqTSca1FmM
I use grabber clips on a coax cable with a BNC connector and the freq counter to test signals inside of the radio, as they make it easy for hands-free operation when going through the alignment procedure.
http://www.amazon.com/Elenco-Electronics-TL-3-Minigrabber-Test/dp/B0002JJU14
Thanks everyone.
Rob, just what I needed, I'll get to making the RF sampler and ordering the probes.
Where do you get your parts, like the BNC connectors for in the boxes?
