WTS MFJ 969 Roller Antenna Tuner
dksac2
Jun 8, 2013
35
9
18
I bought this tuner new about a year ago for use with the HF radio I bought after getting my General.
Thing is, I also got a Gap Challenger antenna and it is always below 2 to1 SWR on each band for the entire band on every band, so I never used the tuner.
It's like brand new, a couple small scratches and as I said, never used. I need to buy a larger tuner for a 1200 watt amp or I'd keep it and need money for buying the larger tuner. Comes with instructions and plug for meter light and meter or uses a 9 volt battery for the meters. It has a built in dummy load and 4 to 1 Balun for balanced line and 2 position coax switch. It's also a true roller tuner, not like the Versa Tuner II, which is not. All controls turn smoothly. It has a built in cross meter, SWR/Power.
Sell for $165.00 shipped.
It would be best to contact me at kf7vxa@gmail as I check that a couple times a day, second best here.
I prefer a USPS Money order.
Thank You, John, KF7VXA
