WV4L-Delta Loop
I would put some sort of guard around the cables at the A/C unit,........... or else a weed wacker is gonna get them:crying:
nice install
The coax is suspended high enough all the way to the entry panel. It doesn't touch the ground. So I'm good there. I will take the slack out of the white wire (which is a ground) to clean up that part of the install later. I just hope I can get the grass established here so I can have some fescue to weed wack later.:blink:
Grate job on antenna set-up ! Realy grate too see you have the realistate to do what you want , must still be some antenna projects to add to the tower ? later Bob.A. "Lucky13"
Thanks for the flowers on the set-up.:wink:
I don't have any plans right now for any other additions to the tower.
The Hex Beam gives me 20-6M coverage and the UHF/VHF Beam covers me for 2M vert. & horiz. and 440 vert.
I can match the Delta Loop for 160-6M.
I'm still on a learning curve for the beam. This is my first beam. It is working great. Making lots of DX contacts.:thumbup:
  • @ Catalyst 122:
    Who do I contact for a name change. I put in for it over a year ago and it says still under review.
