Yaesu FTM 350R setting up the time
rhyary
Aug 24, 2010
7
When I set up the time on the 350, it reverts itself to 1 hour back.
I doubled checked my time zone five times and it is correct.
I tried with Tim signal on or off.
I have the GPS option.
I set the time, it is correct for a some minutes and than revert it self to one hour back.
What am I missing?
I upgraded the firmware this morning and it is doing the same thing.
It does not just go back one hour.
If it shows 7 O'Clock and I set it to the correct time, it goes back to 7 O'Clock.
if I set it to 9 it goes back to 7, not to 8.
I think it gets the time from the GPS and somehow it does not know to move it up one hour.
It does sounds like a day light saving issue, so when the clock will "fall" behind one hour it should be OK. But I did not find anywhere Day light savings option.
Could it be that with no DST setting that you have to change the time zone compared to Zulu(GMT). I am in the Central time zone, normally GMT -6 hours but during DST I am GMT -5 hours
  • @ heartbreaker3473:
