Yaesu M1 Reference mic (Offers?)
Greg T
WDX-945 (Jazz Singer) Upper Peninsula of Michigan
Sep 18, 2014
1,486
2,535
273
72
Escanaba, Michigan
This mic is sweet and sounds fantastic, BUT, has an issue. A couple of years ago I noticed the frequency controls for the EQ were getting a bit wonky. I could get them to work, but had to diddle them a bit. I called Yaesu and they said the warranty was two weeks out. I paid 300 bux to have it repaired and they installed a new board. So, I now have about $1000.00 invested into this mic. Well, the controls are doing it again. They are still useable, but you have to diddle them a bit to get the desired level for a given freq. I don't have an issue with this because once you get it set you can forget it.
This all being said, I don't need the mic anymore as I have way too much money invested in stuff. So, if the right offer would come my way, I would let it go. I have all the original packaging and manual, power supply and USB cable. I also have an adapter I'll throw in that mates it to a standard 4 pin. I'll throw that in. I'll put the mic specs in the post so you don't have to look it up:
Also have a good quality dust cover that will go with it.
Main Specifications​
SpecificationDetails
Microphone TypeDynamic + Electret Condenser dual-element
Frequency Response30 Hz – 17 kHz
Sensitivity-60 dB (1 kHz, 0 dB = 1V/1Pa)
Microphone Impedance600 Ω
Power RequirementDC 5.0V ±5%
Current Consumption160 mA typical
Headphone Output Impedance16 Ω
Headphone Output Level15 mW typical
RX Audio Input100 mVrms typical
Dimensions140 × 280 × 152 mm
WeightApprox. 960 g
ConnectorXLR-style balanced output
Included AccessoriesAC adapter, microphone cable, Treble Boost Cowling
Key Features​
  • Dual microphone elements:
    • Dynamic element for warm low-mid audio
    • Condenser element for crisp highs and DX clarity
  • Independent 9-band graphic EQ for each mic element
  • Two EQ memory presets plus bypass mode
  • Blend control to mix dynamic and condenser audio
  • Built-in DSP low-cut filter
  • 20-second recording/playback monitor function
  • Headphone monitoring jack
  • Large TX LED indicator
  • Contactless magnetic PTT switch with air-cylinder feel
  • Treble Boost Cowling accessory for enhanced presence around 1–1.5 kHz
