YAESU VX-7R -RPT SETTING HELP
darticus
104
4
I programed a good main and sub frequency into channel 3 and it took and was on both main and sub. Somehow It is being saved as a -RPT and I can't change it to simplex. I pick simplex but it always goes in as -RPT. YAESU can't understand this either. I can program the same frequency to the next blank channel as simplex and its ok but not on pre programmed channels as a replacement. I can try to save a frequency that is -RPT or just leave -RPT as the setting if its simplex. Any Thoughts on removing the
-RPT? Is it maybe set by a number somewhere else in the settings. It seems to program in ok but as soon as I change the programed channel and go back it it picks up the - RPT and not the simplex. Thanks for your help Ron
