I have a quandry on my hands. A lot of you have heard me mention that I have an RCA 1 Kw commercial AM broadcast transmitter that I had hoped to convert to 80m and use my TS-820S as the VFO. The plan was to first find out what was wrong with the modulator and then rebuild the output section and retune for 80m.No small task as the entire PA tuning section has to be stripped and rebuilt from scratch. Next I need to devise a PTT and antenna change over circuit and run it remotely as the TX is in the basement and the shack is in the den directly above the TX.I would also need to monitor plate current and ideally grid current as well.The more I look into what I have to do the bigger the project becomes and all this for a single band plate modulated TX. I am starting to think about stripping all the components and using them to build a linear amp that I can use for all bands and all modes, not just AM.The pros of the TX are beautiful audio with a 750 watt carrier which is legal here BTW. That is the legal limit in Canada for AM. There is also the ego factor of saying "The rig here is an RCA BTA-1S modified for 80m with a pair of 4-400's modulated by another pair of 4-400's." I would also be the only station in the entire region to have such a transmitter on the air.The cons are a LOT of work and it will be single band and single mode.At this point it looks like the modulation transformer may be toast but I have another transformer I can make do with by making a few component changes and running no more than 500 watts carrier.Getting all the PTT and T/R sequencing is going to be a chore. The pro's of an amp are all band and all mode. I can still use it on 80m AM with my Heath DX-60 as an exciter/driver.I can build the amp with four 4-400's in the final that will loaf along at the 2,250 watt pep Canadian legal limit for SSB. The transformer is a Peter Dahl rated for 3700 volts at 1.25 amps CCS forever and the rest of the power supply components are very heavy duty as this thing was meant to run 1 Kw AM carrier 24/7 at 100% modulation.I have a pair of 1000pf Jennings vacuum varible capacitors to use in the tune/load positions.I also have a 42 inch high rack cabinet to mount everything in but it will be a heavy beast when it is finished. I figure the power supply alone will weigh nearly 200 pounds with the plate transformer,filament transformer,screen power supply,filter choke etc.Having come from a broadcast engineering background the transmitter has a certain appeal but I'm not sure if it is the best idea or not. TX or amp. What will it be?
