Galaxy DX 959...GNF?
steved
Feb 4, 2008
97
7
18
I just got a Galaxy DX 959, one of its features is a "GNF" or Galaxy Noise Filter which is supposed to reduce the "rushing noise."
I've been running it a little, and while it does help quiet things down, over half of the RX transmissions are distorted (like they are seriously over modulated). If I defeat the GNF, everything sounds normal. When engaged, the RX is distorted bad enough that you cannot understand over half the people talking.
Is this normal for the GNF?
If it was in the manual, I must have missed it...what I read seemed to indicate it could be used on any of the three bands.
Thanks for the responses, that will make it a little less aggravating!
I think you mean modes of talking like AM, FM, and SSB. Bands are what channels or frequency’s are grouped into.
Now if we had something like a switchable channel guard crystal filter that would be a good use for that switch. The Gnf just sounds bad.
GNF works well when mobile, while in very close range with another radio. it allows me to use am/ssb at a very close range (knowing the mic gain can be backed way down). if your neighbor had a base and you talked to them a lot. it wipes everything out but a very strong signal, including some horrible interference squealing found kon some lsb frequencies.
i came here looking to find out if GNF could be calmed down, a lot, by changing a resistor or some board component. maybe turned into a mild high cut for bacon white noise that the 3 stage tone can't sort out?
I never use the gnf. It's supposed to be for ssb only not am at least that's what my manual said, hopefully someone will have the answer you're looking for. 73.
Reactions: c316buckeye
Probably more than one. Would be cool to figure out which fixed resistors to sub with potentiometers. Might be tuneable that way. To do it with fixed parts you'd have to work out the new component values.
Have fun with that. Not on my bucket list.
